I pulled the inspection plate and measured 67 thousands worth of movement when the clutch is depressed, so it looks like pressure plate movement is not an issue. I also measured the pushrod travel on the master with the line disconnected, just shy of 3/16ths before it becomes had as a rock.
I also did another master and a half worth of gravity bleeding just for fun, I didnt notice any bubbles come out of it, and the clutch feels about the same as it did before.
I also thought I'd check the level of the tranny fluid since I've been noticing it dripping more. I probably put 3 tablespoons in before it started running out the fill hole. I dont know if I'm imagining it or not but it seems a tiny bit quieter when its all the way full.
I didnt notice it creeping today as badly as it has in the past... Still difficult to get into first at a stop, but for some reason its really easy to get into 4th. Once you're in 4th, you can slip it right up into first like nothing is wrong.
What would the symptoms be if I had really worn synchros?
