LS swap! finally
Mackhedq
146
minnesota
If youre gonna be dumb you gotta be tough
Yeah just don't ls swap your ranger. Nothing fits at all. Was gonna SAS but I can't give up on these beams. Just too much time and effort in them, plus I can't do anything the easy way. Couldn't get the engine to fit at all comfortably. Too close to beams at full tuck but why do I need 23"+ of travel. Pushing the entire front suspension forwards 3" and moving the mounting points out 2" each side. Or I might add 2" to each axle beam. Well see
Blmpkn
Toilet enthusiast
6,374
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Keep at it.
Building the best generally ain't easy.
Mackhedq
146
minnesota
Still coming along. Haven't touched the V8 a minute here, motor didn't fit with stock steering box and with pushing the beams forwards I ended up using a Toyota ifs box. Extended the beams too. This helps way more with travel and tire not completely eating the fenders. Gonna use 2.5x14" coilovers for this. I've got everything ordered except for coilovers now. Need to finish beam mounts, put motor in and then I can weight the truck for coilovers. I already took down front end unsprung weight. About 550lb with drivers side beam being heavier. Swingset will add probably 30-40 lb but that's a non issue. Knowing from what I learned the first time around in excited to build this next set. I'll need some fiberglass pre runner fenders but I'm not willing to spend over 450 dollars on shipping them alone.
Mackhedq
146
minnesota
Alright I guess this is a suspension rebuild thread now and not even V8 anymore. .188 wall 1.5" Dom. Looks way cleaner than the old arm. Couldn't reuse the last ones and these "should " clear 37s with minimal rubbing, I can always add front wheel spacers back but then the track width front to back will be wild
Mackhedq
146
minnesota
Everything just kinda fell into place now. Gonna order coilovers next and get started on that once they arrive. Moving the axle forward was the right idea. Working on plumbing, wiring and headers/exhaust. Then I'll pull everything to clean it all up, finish final welding touches and paint.
Mackhedq
146
minnesota
Weighted the ranger today for coilovers! 1250/1192 front and 1010/987 rear got my coilovees on order now
Mackhedq
146
minnesota
Rainbow spaghetti! Getting tired to fabbing and waiting on coilovers plus I need to fill my welders gas. Wiring is something I weirdly enjoy. LS computer is controlling engine and transmission. I'm still using the ranger side for climate controls though. Transfer case is manual shift.
Josh B
1,988
Oklahoma
I actually can see where you are going with that, and it is an incredible task. Salute!
I had a late 60s, early 70s Dodge Dart that burned the wiring while stopped in some construction. It wasn't mine till that happened, and I found it had aluminum foil wrapped around the brake light fuse.
I pulled the harness and hung it on a garage wall, tack by tack, and re wrapped it bit by bit.
I also did some drafting early on, with a qualifying record of having taken a high school class on it, they said "that's ok, we'd rather you learn it our way". I spent a couple weeks learning how to letter on Reunion Arena in Dallas, electrical grid, and the next week counting every iron connector on three pyramid office buildings in Houston.
I have a vague idea where you are headed with this, cheers :)
Thedrill
15
los angeles
2001 xtra cab
ford ranger
Reminds me of my Old Ls 4.8 swap into my XR4Ti but I wimped out with a 700r4.. and a very pared down chevy express loom.
Good work on the RANGER.
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Ok, not really, but that's funny.
BTW, Nice work so far.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
It is easier than it looks.....if your easy is my easy...it's even easier than that. Except on Thursdays....
scotts90ranger
4,447
Dayton Oregon
2.3 Turbo
As someone that has made several engine wire harnesses by hand and drawn many for work, engine wire harnesses aren't rocket surgery as long as you know where the wire goes at both ends and how you want to route it... the hard part is starting with one that's already a thing and making it into what you want then it gets into a spaghetti mess for a while until you clean it up...
