- Aug 7, 2007
- 536
- Costa Mesa, CA
- Ford
- Engine Type
- 4.0 V6
- Engine Size
- 4.0 SOHC
- 2WD / 4WD
- 4WD
- Tire Size
- 33"
I know this may be nearly as hard as finding hens teeth, but I may need one. I thought I found a remanufactured one through Auto Zone rebuilt by Zumbrota. I even spoke with the Zumbrota representative and he told me they had cores to rebuild. Unfortunately, he was mistaken and they have none of those cores.
Apparently I made a mistake by sending my totally functional transmission with 240K miles on it to a shop with a very good reputation for a check up to make sure I would not get stranded in the wilderness some day. They determined all was good except 5th gear was worn. I they replaced all the bearings, 5th/reverse gear assy, 5th gear retainer plate, 5th gear slider and all the seals. It worked well for about 6 months and it started popping out of 5th gear occasionally. At around 13 months it suddenly would not stay in 5th gear at all. I took it back to the rebuilder even though it was beyond the warranty. They found 5th gear was worn again and replaced it at no charge. Then about 10 months later it suddenly started popping out of 5th gear again.
I am thinking there may be something in the case that is worn and may be the problem.
The rebuilder told me to bring it in again and they would look at it to see if they can determine why it keeps failing. I don't know if I can trust them anymore.
So, I would like to find another transmission. Unfortunately, it needs to have the mounting boss for the manual shift transfer case linkage. Does anyone have any idea where I might find one?
