vbrad511
- Jan 6, 2008
- 5
- Springfield, Illinois
- Ford
- Engine Size
- 4.0
Hey all, I've got a 2011 4wd Ranger. I've been considering the conversion to manual hubs since I got the truck, as I don't offroad, and the only time I need 4wd is when it snows here, which isn't much any more. To add to it I'd like to see if it ups my MPG at all. Recently I've found that I've got a front hub bearing getting sloppy, so now's as good a time as any.
I've read the conversion thread here on the site, but I have a few questions. First off, will the abs connectors on the older model hubs plug into my '11? If I have to cut/splice, will it affect anything with the system? Second, the conversion thread talks about using new bolts? Is that necessary? Are they a different thread/pitch, or are they TTY? If they're the same, would a bit of Loctite on the old bolts serve me just as well? Third, it talks of installing a seal on the backside of the knuckle. Is there not one already in place? If so, will it not work with the new axles? If not, will there be a recess in the knuckle on my '11 for the seal?
I've had my '97 apart a handful of times, but it's a different beast than this one, so I'm hoping somebody here can give me a bit of guidance. Thanks..
