Liftgate Handle Latch...Need Help
wildbill23c
577
Southwestern Idaho
215/70-R14
Rust makes holes in metal. Just wait a while.
Apparently none of you have owned a Bronco 2, otherwise you'd realize the rear hatch isn't metal its fiberglass.
ericbphoto
Overlander in development
16,598
Wellford, SC
6"
Yup. Haven't had one yet.
My bad.
sgtsandman
Aircraft Fuel Tank Diver
12,651
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Nope. Never have. Just Rangers.
wildbill23c
577
Southwestern Idaho
215/70-R14
With the terrible design of that handle/latch mechanism I think you are better off skipping the Bronco 2 LOL. That's a very horrible design sadly no parts available anymore so we are stuck trying to cobble stuff together.
Do you know if the Ranger tailgate handle pieces where the 2 rods connect are metal or plastic by chance? Wonder if there would be some way to make a tailgate latch work?
sgtsandman
12,651
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
Since that is the case, a thin piece of metal as a backer might not be a bad idea. Or a wide washer to back up the fiberglass. Half of my utility rebuild project is hardware from my local hardware store. I might have more money invested in hardware than I do wood.
sgtsandman
12,651
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
I'm pretty sure they are plastic. It has been a while since I had a Ranger tailgate apart.
wildbill23c
577
Southwestern Idaho
215/70-R14
After the weather clears up again, I'll pull the parts on the hatch apart and see what I can find out. Wish I could remember where it was I found the Explorer handle mod LOL.
RobbieD
2.9l Mafia
3,454
Georgia
@wildbill23c On my '84 Ranger the tailgate release rods were held onto the latch arms by the plastic pieces. I tried these:
36671
(Dorman 75451) which were the closest aftermarket replacements for this type that I could find, but these are listed for later model Fords, They didn't hold up at all; the arm thickness or hole size may be different on earlier models.
Here is what I end up using instead on my Ranger (and these are holding up well), which are metal throttle rod clips:
36673
Most parts stores carry these clips individually, but the Dorman 41016 pack has three sizes, and includes one each in LH and RH. I cut thin slices of plastic tubing to make bushings for the rod ends (fills the gap in the arm holes where the original clips' "fingers" were), and I squeezed the new clip retainer tabs so it clipped onto the rods real tight. I think I used 4mm pneumatic tubing to make the bushings; simple slice with a razor knife, the thickness of the arm, and they worked perfectly.
I also remember an article somewhere on replacing the original B2 handle with an Explorer handle, but I can't find it either. I used these clips on my Ranger gate; my B2 rear latch still works so it's still original. I don't think that a Ranger gate latch handle will work on a B2; it mounts to the inner wall and requires a large rectangular hole in the outer wall sheet metal. I'm sure that whatever fix you come up with will be better than the original setup. Good luck!
P.S.- Please try to forgive those who know not the way of the B2, for they are still lost in the wilderness.
wildbill23c
577
Southwestern Idaho
215/70-R14
P.S.- Please try to forgive those know not the way of the B2, for they are still lost in the wilderness.
I'm hoping the original parts that the latch rods are connected to will connect to the explorer handle, I only grabbed the handle mechanism, couldn't get the rods out of the rest of the mechanism at the pick a part, no worries plenty of them over there if I have to return to grab more parts LOL.
alwaysFlOoReD
5,094
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Takes some pics and write an article....
QUOTE="wildbill23c, post: 1720968, member: 70218"]
[/QUOTE]
wildbill23c
577
Southwestern Idaho
215/70-R14
I'll try and get some pictures of the disaster when I get started. Dang weather decided to go from spring back to winter again so it'll be a while...and I don't see any immediate need to get to anything in the back of the Bronco 2 LOL...I can still crawl over the back seat and trip the latch if I need to though.
ecgreen
287
Dunbarton NH
Ford Bronco II
3"
I thought my magnet was broken...
