Exhaust would also blow white "smoke" most of the time as coolant was being vaporized
No white "smoke" means no blown head gasket usually
Cold engine
Remove rad cap
Make sure rad is topped up
Start engine
Coolant may burp out a little then stop
If coolant starts to over flow as engine is running then blown head gasket
No, coolant "stop leak" won't work on blown head gasket, just on rad leaks
I have used "block and head gasket fix" and it does work but................just temporary, maybe a month or two
Its liquid glass that hardens when it comes into contact with the 1,000deg cylinder temps as a cylinder fires
But constantly being broken off and replaced, so you run out of liquid glass, lol
And the break/breach in the head gasket just keeps getting bigger all the time and then it can no longer work
Pull the head when funds permit
