leaf spring free arch?!
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
I am shopping for leaf springs, already started a thread on determining weight rate, but this subject probably deserves its own, for I have also found various free arch options.
I get what it is, but what does it translate to? what are the pros/cons of more or less free arch?
How does more free arch affect it? (axle wrap/travel/ride height etc)
Once again google failed me, but you guys always come through!
Ramcharger90
1,708
N/A na
306, Bcam,
Blmpkn
Toilet enthusiast
6,359
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Spring rates being the same, I would imagine more free arch would mean more travel, therefore higher ride height. It would decrease the eye to eye measurement.. But the shackle would just swing forward a touch to make up for it.
Your just over complicating things I think :p although, you do have me curious to learn something new though so keep it up lol
lvwill
143
Las Vegas Nv.
2.3 EcoBoost
2.3 Ecoboost
I was looking into this a while back. There are f150s that have the same width and length springs with enough arch to eliminate the factory blocks. I got distracted and discouraged on the project and never went any further. Now the ranger got replaced with a 2020 but the b2 is still under construction in the garage.
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
Agreed, I am an overthinker....I am sorry, and also you are welcome lol.
On that note, what you said makes sense, but now what if my shackles are worn/tweaked/bind...I'd maybe replace them too just to be safe.
I am also a what if-er 🤷‍♂️🤦‍♂️ I have problems....
Options can be a blessing and a curse. It leads me away from "give me the cheapest u got" and into the "give me one of each"....
Trying to avoid both, or find the balance between them, Id like to ultimately find a nice set of stock replacement leaf springs to get me by until the next phase of installing a lift kit (which could be days, months, years or a decade...my life is sedentary yet volatile)...and in the meantime provide a good compromise of load tolerance and ride quality.
Im thinking max free arch springs (6") , 3/1 4 leaf, 1-7/16" thickness in same load rating (1100lbs), and some good shocks with maybe a lil extra travel, and replace the shackles if suspect....
My other consideration being 4-13/16" free arch, 1250lb, 4 leaf (3/1), 1-7/8" pack thickness....
Decisions decisions.....
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
So I did some research and from what I could find, stock spring arch for the 1100lb leafs is 6.5".....I would definitely like to eliminate the stock blocks.
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
Would you happen to know what year(s) F150 leafs fit? I would definitely like to eliminate the factory blocks.
lvwill
143
Las Vegas Nv.
2.3 EcoBoost
2.3 Ecoboost
It's in the 90's
Leaf springs are the same width and length and pin in approximately the same location.
If I remember correctly the 1750 springs would eliminate the factory blocks. I think that was the lightest springs available at the time. Please
