- Aug 7, 2007
- Reaction score
- 538
- Location
- Costa Mesa, CA
- Make / Model
- Ford
- Engine Type
- 4.0 V6
- Engine Size
- 4.0 SOHC
- Manual
- 2WD / 4WD
- 4WD
- Tire Size
- 33"
I have posted before about an issue I have with transmissions popping out of 5th gear. I just installed a Zumbrota re-manufactured transmission that was a replacement under warranty. I seems they used the wrong gearbox housing. It is missing the right side (passenger side) upper bolt hole that is used for the 4.0 SOHC engine. I think the housing is from a 4.0 OHV (push rod) engine. So, I can only use 7 bolts instead of the 8 that my original transmission used. It has the two holes at the very top that are normally there but is missing the one hole on the right that is slightly down from those holes.
I am going to contact Zumbrota to discuss the situation. It was built in January and should be covered under warrant but I am tired of changing transmissions.
I didn't see it until I had the transmission fully installed. I really don't want to take it back out. Do you think I will have a problem with using only 7 bolts?
