2.3L ('83-'97) Keeps cranking
Otto57
7
Michigan
Carbed 2.3 with no spark keeps cranking with the key out. Replaced coil, ignition module key switch and relay on fenderwell. What else could cause these problems? It was starting up fine until I had a fuel leak from the tank. Replaced the tank and send unit and it started and ran to the street and died. Any ideas? Thanks
oldgeek
1,027
USA
Ranger XLT
To understand this, you take the key out of the ignition and the starter keeps cranking?
Otto57
7
Michigan
It keeps cranking until I disconnect the battery. I can connect the battery again and it does not crank until I turn the key again. This is making me crazy.
oldgeek
1,027
USA
Ranger XLT
Maybe the starter solenoid gets stuck while energized? Or is that the relay you referred to?
Otto57
7
Michigan
Well, I replaced everything except the ignition switch on the lower steering column. Thinking maybe a bad ground? Seems odd that I have no spark and it keeps cranking.
oldgeek
1,027
USA
Ranger XLT
That is interesting. My first thought was the solenoid getting stuck while energized and when the power is removed, it disengages. Then I wonder if you have a short in the ignition switch, but why doesn't it continue after reconnecting the battery cables?
I'm going to be watching this one.
55trucker
183
Oshawa, Ontario
mild
Put a remote starter across the starter terminals & see if you get the same result. If the issue does not happen with the remote the issue is upstream.
Otto57
7
Michigan
If the ignition switch on the column is bad, would I still have power to the starter? I don't have a remote starter, can I get same results by jumping the terminals with screwdrivers? I hate electrical issues.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,521
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Screw driver will work... ensure it's in park or natural. Pull the small ignition wire from the fender mounted relay... jump it and see what happens.
I suspect that if it had a bad ground... you would have entirely different set of symptoms.
Otto57
7
Michigan
Jump the small wire instead of main power lead? I used to jump main lead.
Uncle Gump
Token Old Guy
13,521
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
No... big hot terminal to the small terminal on the relay.
Otto57
7
Michigan
Ok, I will try it when I get home from work. So if it turns over normally and stops, then the relay is bad. Correct? Thanks.
Uncle Gump
Token Old Guy
13,521
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
No... it would mean the ignition switch was causing the constant crank.
If it still does it... the ignition switch is good and the relay is bad... sticking.
Otto57
7
Michigan
Got it. Anxious to try it tonight. Thank you
Otto57
7
Michigan
Ok, guess I have another bad relay. Kept cranking when I bypassed the relay. If I'm not mistaken the relay also sends voltage to the coil and I have no spark
