Str8sixfan
- Mar 25, 2012
- 2
- Ford
- Engine Size
- 2.3L
So here's what I've done to the truck in the last almost 2 years.
Mileage started dropping when a check engine light came on in August of 2011. Right before that I was getting 23.5mpg fairly consistently highway miles. Pulled the PO171 code, ended up replacing the pre-cat O2 sensor. Took care of the CEL for about 2 months or so, but then came back on.
So mileage still sucked. Replaced the fuel filter later that fall
Last fall (2012) I replaced the plugs and wires
New air filter at the beginning of this year
Tried Seafoam a little later
Various stops along the way, I've re-set the battery and got the CEL to go off for a period. It's been off for a share of weeks right now too.
Anyway even with the new summer blend of fuel out, I can't even hit 20mpg (about a 19.5mpg avg now).
Where do I begin to look next? Compression check? Most vacuum lines look perfect. EGR? Plugged cat? Truck's never been speedy, so I can't really tell if it's lost power compared to what it was, doesn't seem really any different, though I could have suffered from the toad in a warm-boiling pot syndrome. I want to say it kicks down on interstate a little more than it used to, but that's really hard to quantify. I mean this truck is now 16yrs old, so the cat could be plugged for sure. I just want to know what types of things could I start checking on my own to make sure it's tuned up and running like it could.
