interchangable parts list
1986fordranger
central VT
2.3l/4.0l
1991 to 1994 explorer headlights , turn signals , rad support , grill, and hood will interchange with 1989 to 1992 rangers and 1989 to 1990 bronco 2's
1986 to 1988 extra cab ranger rear corner windows interchange with 1989 to 1992 ranger's and vice versa , as does 1993 to 2011's
ThB14
mazda
will 99 b4000 doors bolt on my 05 b4000
ThB14
mazda
would 1999 ford ranger doors and box bolt on to my 05 mazda b4000
Colin
182
ON Canada
Mazda
yes, do you guys even read before posting?
green_duck42
New Hampshire
Bringing this thread back from the dead.
How about leaf springs. Found a set on Craigslist from an 88 ranger and wondering if they will fit my 98.
green_duck42
New Hampshire
Rbv= Ranger Based Vehicle
alaskan155
6
washington
FORD
7.3l/4.0l
ill bust it down in simple form
83-92 are the same(minus dash and front fenders/clip)
93-current are same(minus 3/4 door, dash in 95, and ifs in 98)
core supports/radiator changes break dowm
83-88
89-92(can be modded for 83 headlights/grill) if need be
93-94
95-97
98-current
firewall(only 2 designs)
83-94
95-current
doors(2 designs)(explorer doors and mirrors do not interchange with rangers)
83-92
93-current
the inner structure is the same from 83-last year, so the body mounts are the same minus the radiator support on the front for the 98+(frame horns are a little wider)
back window interchange
regular cabs are the odd ball, 83-97 reg cab back windows interchange
ext cab is 83-current, and 98+ reg cab(only cab that wont bolt to a 97 and older frame) share the same back window
2wd ranger frames are the odd ball, all other rbv are based off the 4wd chassis up to 97.
95-01 exploders have the same front suspension 2wd or 4wd as the 98+ torsion bar rangers
add more as i think of there are differences in wiring.
body lines are different on explorers but the floor pan for the front is the same as a ranger extended cab.
BAGGED92RANGER
I have a 92 ranger that is bagged and body dropped so that it lays rockers on the ground I was wondering if I can put a 99 front clip on it fenders hood everything I already have the 99 but just want to make sure it is possible to do before I try it any advice would be great thanks ahead if time
chazzone
9
Camby, IN
No disrespect, but if can butcher up the suspension like that, slapping a few body panels on it shouldn't be any kind of a challenge.
Fordguy_83
Ontario, Canada
1983 Ranger v8
302-ish...
New guy here... What about using a dash out of a 94 or so ranger, in an 83. Or, is there a dash upgrade that people have done with relative ease into an 83-88 ranger?
boosted2.3
Hello, I read this and was wondering about myine. It's a '94 extra cab XLT with a 4'0. It sits as high as a 4x4. I get ask all the time if its a 4x4. It has a towing package I know. 15 in. wheels and has 235's on it. I was told by a guy that it was probably a "high rider" but now after reading this I'm puzzled. I know is not a STX. It was a georgia truck that came to EV when a guy xferred his job up here, and he bought a 4x4. Great truck too, and no rust at all. I have 160 k mis on it now and I think I have some front end issues. I also have a gen I LB that I put a 23 turbo in, but I screwed up and trusted a body shop to do some work, and he talked me into a repaint and he butchered my wheel wells so bad and I just parked it and got this '94. The thing is I have a new front end under my gen I '85. I replaced everything on it but the beams and spindles. and a big sway bar. It handled like a car after that. I'm trying to find out if the front end parts will work in the '94. Hope you can help THX
d1rtyharry
i have a 97 ranger 4x4 with the 3.0 and was wondering about the front driveshaft and what is interchangeable with it?
