01Ranger86
- Jul 12, 2020
- Reaction score
- 0
- Location
- Saint Louis
- Make / Model
- Ford Ranger
- Manual
Hey everyone, this is my first post. Short story break down... I broke a bolt removing my water pump which caused a cascade of events and now I am about to replace my timing chain/ gears. I've never been this far in my engines guts so this is all a good learning experience.
When I was removing my harmonic balancer bolt, I'm pretty sure I moved my engine out of top dead center where it needs to be. I am about to replace the timing chain/ gears but do not what to install the new set until I am in for sure TDC. ....... My question is if I rotate (using my old chain/ gears) to where both my timing gear dots are lined up (6 oclock for upper, 12 oclock for lower) will I technically be in TDC? Then I can install my new timing chain/gears? The timing chain was extremely loose and may have adjusted itself over the years I realize.
I attached a picture of where I am at, just looking for some tips on what the next steps should be as I do not want to install this new set of gears and chain and be out of top dead center.
Thanks for the suggestions!
