infamous 97 4.0 lean codes
tworanger
Lynden, WA
2.3
My 1997 ranger just starting throwing the p0171/p0174 codes-does ford or any aftermarket company sell a kit of gaskets to solve this issue? Fordparts.com has a couple kits and i would prefer to use ford brand because of the rubber gasket instead of the cork. I also noticed that they have two kits (#9424) for the intake on the 4.0, the window sticker has the date august 1, 1997 so am I right to assume i have the "FROM 11/29/96"? I'd like to get by with just replacing what needs to be done, if anyone knows the actual intake and fule rail gaskets(with part #) that would be a great help. I have seen a lot of info on here about this issue and sorry if this seems redundant but i haven't seen any info on the gasket kits(or if they exist)
3,614
Well assuming that your issue is genuinely intake gaskets then yes, Ford sells intake gasekts for your truck.
97RangerXLT
TRS 25th Anniversary
4,019
Fishers, IN
2"
31"
yeah make sure it isn't a vacuum leak around the intake first off. spray some carb/choke cleaner around the intake at various spots including around the brake booster and if the engine revs up, you got a leak... fix the leak.
Now that you have done that and it passes, you do have a 97, and there is a TSB out for the gasket between the fuel rail and lower intake that goes bad and will cause those codes to pop. replace it and you should be good to go. not too horrible of a job, but getting the upper intake off can be fun...I did a write up on it a few years ago. I will post the link to it for you, at least you will get an idea of what you are getting into.
AJ
97RangerXLT
4,019
Fishers, IN
2"
31"
And here you go:
http://www.therangerstation.com/forums/showthread.php?t=94437
wow two years ago to the day...anyhoo, the info in there should have part numbers and everhthing you will need to do all of the gaskets. You won't need to do the valve cover gaskets but if you decide to, once you have the upper intake off you can go a few more steps to do them as well if they are leaking. If you do just your fuel rail gasket, and not the valve cover gaskets or lower intake, it will take you about half of the time and aggravation as doing the valve covers and lower intake as well.
AJ
Dune Runner
Alpine, Ca
A dirty MAF will cause those codes also. Do you run an oiled K&N air filter?
