I'm not sure where to ask this?
Daniel Black
44
Leicester, NC
302
205/60R15 & 225/60R15
I have an '87 2WD Ranger and I have access to a complete '96 2WD front suspension for the twin piston caliper upgrade. I'm wondering if the front track width is wider on a '96? I know the rear axle is wider so I would assume the front width is too but I'm not sure. The '96 beams and radius arms are already removed so it's hard to measure. I don't want the front wheels sticking way out for a tiny upgrade in braking.
alwaysFlOoReD
5,122
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I've never read anything about that swap making it wider. Doesn't mean that it won't. Hopefully someone with more knowledge than me ansewrs, I'm interested too.
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Nope. You need to get a Chevy. Away with you. Shoo!
Bird76Mojo
1,265
IL
If I ever get my parts installed, I'll be able to tell you. I've had everything painted, preassembled, and ready to go for a while now, only I'm using the Sport Trac rotors with a caliper relocation bracket I made.
Daniel Black
44
Leicester, NC
302
I'd put my junk in a wood chipper before I'd own a any GM product. You're basically telling the world you're built like a Ken doll from the waist down when you buy a Chevy anyway. If you could get the track measurements when you get done that'd be great. I haven't read anything about them being wider either but those year model trucks are visibly bigger than 1st gens.
Ranger850
Doesn't get Sarcasm . . .
4,696
Tallahassee Florida
Stock 2"
Stock
IF it does make it wider, you could possibly get a '96 rear axle and that should put the rear wheels in alignment with the fronts
Dav
26
riverview, fl
ranger xlt
, 2.9
none but it is a convertible
stock
my '88 now has 96 beams and brakes. it measures 49 1/2 inches between rims, measured directly under the ball joints at the lip at the widest point of the rim. the rims are stock aluminum rims.
i have not noticed any great protuberance of tire from the wheel well but i would say , if there was no rubber on the rim and a straight edge was put on the outside of it, the edge would hit the fender about a half inch into the wheel opening. hope that helps.
oh, for those red necks amongst us, protuberance means 'stick out'
ericbphoto
Overlander in development
16,659
Wellford, SC
3.0L
6"
Well, technically, protrude means stick out. Protuberance is the item that protrudes.
But that's an awful lot of spelling issues to say "sticks out".
Ranger850
4,696
Tallahassee Florida
Stock 2"
Stock
What is the rear measurement. Is the front wider than the rear.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,506
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I kinda like... protuberance.
Ummm… I also knew what you were talking about.
Who knew it was an actual word?
protuberance
[prəˈt(y)o͞ob(ə)rəns]
NOUN
  1. a thing that protrudes from something else.
RobbieD
2.9l Mafia
3,524
Georgia
Cool; yet another name for the old hootus. "Protuberance" even sounds, like, scientific.
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,701
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Bigger words almost always make one sound more intelligent. Surprisingly, I knew what the word meant with out even needing to look it up. I guess some of that edumacation I got stuck.
Dav
26
riverview, fl
ranger xlt
, 2.9
stock
the rear measures 48 13/16 so the front is about 3/4 inch wider. although i have the mustang rear disc setup, the rims still mount right to the axle flange, no change there.
i have a front sway bar. what a difference it made in handling. love it. but, there's always a but, it interferes with the sleeve for adjusting the alignment. the bolt hits the bar. have to remove the bolt to turn the sleeve. once it's all tightened up, it doesn't hit anything. no idea which truck donated the bar beyond a series 1 or 2. may even have been a 4wd. when i put it on, i had a set of plastic links and a set of steel ones. one of the plastic had split so i used the steel. don't remember if they are the same length or not.
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
The 96 axle will be a bit wider, but if you stay with your stock tire size the tires will stay inside the fenders.
