i think my u-joint is done
lifted_Mazda01
Davie, FLA
Mazda
everytime i accelerate the driveshaft or something around the rear end sqeels like a pig, soon as i let off the gas it stops, or coming to a stop. i think its the u-joint, any other ideas??
Stumpy
Tacoma area, Washington
Climb under and take a look, usually when a u-joint is bad it's fairly obvious. You might have to pull the driveline off to get a better look, there shouldn't be any play in the joint at all. They're really easy and cheap to rebuild too.
Wicked_Sludge
43
Westport, WA
3-point-GO
u-joints usually produce an intermittent "squeak, squeak, squeak" as the driveline goes 'round. id still check it, but my bet is the u-joint isnt the problem.
bobbywalter
Ugly Truck of Month
4,680
woodhaven mi
FORD mostly
BIGGER
sawzall?
two piece driveline?
sure it isnt a belt? or a loose skidplate rubbing the shaft?
LITTLE FOOT
BUFFALO, NY
FORD
5.7
mine did that. it was the u-joint
thegoat4
6
Take it on a short drive, the park and feel your u-joints. If you have a bad one it'll be burning hot, or just hotter than the rest, depending on how you drove it.
Bryan22
4
So-Cal babay
94 extd
94 2.3
Get under the truck grab the drive shaft and rotate it back and forth. look for play in the joints. also check the bolts that attach the driveline to the diff. they came loose on my 92 once and made the truck act really funny. That being loose along with a bad U-joint made a hell of a racket too.
lifted_Mazda01
Davie, FLA
Mazda
ok will check tomorrow b4 work thanks guys, if not u-joint what else, cause its obnoxious and i dont want to end up stranded
PaleBlue90
5
Aurora Colorado
FORD
2.3,2.9 and 4.0
my u-joint did that, i went to get the part during school and and on my way home it failed breaking the ears off on my driveshaft :(
bobbywalter
Ugly Truck of Month
4,680
woodhaven mi
FORD mostly
BIGGER
sawzall?
a bad joint vibes.
didnt see where you had a vibe issue.
so i was under the assumption you looked and didnt see an obvious joint fault and was wondering if it was starting to dry up and was gettin ready to fail..and this was a condition leading to it.
the hanger bearing on the other hand will squeal as its last days approach without big vibe issues initially. with worn or failed tranny mount/engine mounts it can load the bearing to where it will squeal or shift the drive shaft to rub something.
i could never know without phsically inspecting the vehicle. could just be the brakes...broke spring or simply worn...or the rear wheel bearing is going...leading to a shift condition in the situations listed...
:fie:hell i could go on and on...
lifted_Mazda01
Davie, FLA
Mazda
yea me 2 i just hope, pray, etc its my u-joint, cheap fix, but ball joints and shocks are next
lifted_Mazda01
Davie, FLA
Mazda
yea it was the u-joints, after changing them seems to have been slipping the driveshaft, but got all my balls back tonight
