i need a good used A4LD 4wd
any where there is mud
2.9
hay any one have a good trans mine is slipping bad i cant drive it and i want to get it fixed asap :dunno:
AllanD
TRS Technical Staff
134
East-Central Pennsylvania
1987... sorta
'93 4.0
It is the general belief (believed to the same degree that most of us
will agree that water is wet or Ice is Cold), that "A4LD" and "good" is
a contradiction in terms.... and thus an oxymoron
The only A4LD I would personally trust is one I've tossed into the proper
lake in england and was given back to me along a woman who rises from
the water dressed in shimmering mail.
But if she gives me a choice between the trans and the sword she
can keep the trans.
AD
igiveup
Edmonton Ab. Canada
Hello
Try to find a 94 4.0l Areostar for cheap that runs and drives. They had the strongest of the A4lds. Grab the transmission, cooler, and ps cooling tube, and all the lines. My 85 B2 is happy.
If you do get one for cheap there are other parts that will fit your B2.
Or go 5 speed.
igiveup
zukirider21
5
NJ
2.9
i have an IMMACULATE a4ld for sale, and i mean IMMACULATE. no leaks, no bad noises, no slippling. just like brand new. only problem is its a 2wd. if you have the tailshaft and housing from your old one im pretty sure itll interchage.
TwoWhels
Saginaw, MI
You have to do a full teardown to change from 2wd to 4wd
You really just have to build it yourself...many transmission shops are just looking for easy money...a A4LD has to be done right
Yes there are better autos out there ... but you go to war with the army you got
2.9
ok what years and trucks do i look for (ranger, b2, expo) i have an 88 b2 that i am putting it into
2.9
need trans for 88 b2
i need this or some one to answer me this
if i put a trans out of a 93 ranger but don't change the computer because i don't have it it went with the motor
but i have my vavle body to swap and i did that on this trans but i dont have od now so
can i put in the 93 a4ld and make the electric od on a switch so the comp doesn't have to be changed
Bent Bolt
4
Edmonton,AB
Supercharged 4.0 SOHC
Solid Axle Swap 4x4
90-94 with a 4.0l engine. Check the shift linkages, may be different.
Bent Bolt
4
Edmonton,AB
Solid Axle Swap 4x4
kevinsranger
edison nj
FORD
i just swapped in a 91 explorer one into my 94 ranger, just swapped trans and torque converter, it works great but i dont trust the a4ld for nothing, get a manual if possible!
kevinsranger
edison nj
FORD
oh there is a good one in a salvage yard in long island for $300 or so. i can get you the number if you want
