i need 97 4x4 4.0l manual ranger info
sloth69mustang
central OH
4.0, 2.3, 4.0, 5.8
i am doing a 3.0l to 4.0l swap in my 97. i have a manual transmission and a manual transfer case. so i need to get the 4.0l engine pcm. of course the dealership wants the vin which will get me nowhere. so is there anyone that there that has the same setup that can give the number off their pcm that i can use to find a pcm for my truck. any other info is welcome. if i could use other pcm's let me know. but the closet the factory the better.
racsan
4,505
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
if you dont know, you'll need a manual trans with the 4.0 bellhousing pattern, just beacause its a V6 trans doesnt mean it'll fit. heres something i copied from anopther post:
Bellhousing identification simplified:
TWO bolt starter mounting on the drivers side = 2.8/2.9/4.0
Three bolt starter mounting on the drivers side = 3.0
Three bolt starter mounting on the PASSENGER side = 2.0/2.3/2.5 SOHC "Lima" 4cyl engine.
And I've got no fookin clue what the 2.3DOHC bellhousing looks like.
AD
not sure if my vin would help you, mines a '93 4.0 (ohv, same as yours) but i have the electric shift T-case.
sloth69mustang
central OH
4.0, 2.3, 4.0, 5.8
thanks for the info but that isnt really what i was looking for. i already have a transmission. i need the pcm part number with the same exact setup i have.
sloth69mustang
central OH
4.0, 2.3, 4.0, 5.8
ok i finally figured it out. so i will post the info in case anyone ever needs the same info.
97 ranger 4.0l 4x4 manual transmission pcm code is F77F-12A650-ACB which later was updated to F77F-12A650-ACC. so both of those will work for that configuration of a 97 ranger.
AllanD
135
East-Central Pennsylvania
1987... sorta
'93 4.0
That is an "engineering number" more than it is an emissions code.
the code you REALLY want if you are simply looking for the correct
computer is the four digit code that's printed on the right side of the label
in larger characters.
AD
