How much should I charge for a resto?
85_Ranger4x4
17,833
SW Iowa
Current shop rates at near $100 an hour these days... even if you did it half that... you would have about 40 hours to complete.
$100 is light, most are over that.
91stranger
512
Whats round on the sides and hi in the middle-OHIO
Gets Mo Chicks
4.2 straight six powered by gremlins, goblins and mudbloods.
We all know you don't get your money back on a project like this so the guy should already know that a 30 yr old truck with issues and age is going to be costly to get done right and add AC to it. It's not going to be cheap and I would say he would have about 5-7k in it after parts and labor given that you are pretty re-doing the engine, steering, suspension and possibly interior stuff to get away with a half-restoration. You are going to have to figure out the labor part of it. Only you can decide what your time and skills are worth to a friend. I would say have your friend give you a $3k budget (for parts only) to start with and get the major stuff done like the oil leaks, new suspension/steering components, install AC, and other things to make it ride good. I wouldn't charge him by the hour. We don't ever try to say "dollars per hour" because people lose their head when you say "our rate is $139/hr". It's easier to give them the total amount due. Just let him know it WILL be expensive and it WILL take time.
OldMan2
233
BuckRidge, GA
Do your best to be your best.
Is your friend wanting it painted too?
Junk Collector
Truck of Month
4,800
Rapid City SD
If you insist on flat rating the thing at least break it down a bit... Say $500 to go through and reseal the engine and clean up the engine bay, for example. Another $500 to go through the front end. Or whatever. Just do a little at a time and let him know what the next step is and how much it will cost. I think that's fair for both parties and you can continue or call it quits at any time without hurt feelings.
evintho
Yes, and that would be a completely separate charge.
I was thinking more like $1000 to R&R the motor/trans, reseal the engine and clean up the engine bay. That would also include replacing wear items such as timing chain/gears, oil pump (while I'm in there), valve job (unless heads are cracked), water pump, freeze plugs and flush water jackets, etc. Probably a good time to replace heater and EVAP cores also. Most of the expense would be labor. Another $500 for suspension/brake work. At $1500 total labor I figure I'm way over on the cheap side.
$100 is dealer rate around me.
$160 is more the dealer rate here on the left coast.
Saddle Tramp
748
Florida
It seems to me that your consious in set in the $100/hr range.
Go with your gut.
captainhero
7
I'd also timebox the work - say for example maximum 1 month. You don't want to start finding issues that you feel you have to fix for your friend that make the project drag on forever. If anything goes bad and require extra work then you can discuss how much more that's going to cost. Biggest issue i see is letting the "friendship" make you do things that you will regret.
OldMan2
233
BuckRidge, GA
I suggest doing a thorough check for rust before investing money into something too rusty to last. I see where rust is a serious issue with older Rangers. Mine doesn't have much, but I just spent $600 removing part of the roof and drip edge on both sides of truck and having the roof repainted. I'm either NUTS or IN LOVE.
No members online now.
