How do you flat tow a bronco 2?
Forlorn
47362
Ford Bronco II
I need to flat tow my b2 today about 25 miles; I got a manual with a manual transfer case; if I throw both into neutral, should I be good to transport it by dolly?
rusty ol ranger
2.9 Mafia-Don
7,720
Michigan
177 CID
You should be. Id pry pull the rear driveshaft though just to be safe
8,374
Yes, just put Transfer case in NEUTRAL
Manual trans in Neutral is redundant but won't hurt anything
Transfer case has an oil pump on rear output shaft so even in Neutral the output shaft bearings are lubed so no need to remove drive shaft, but you can if you want
If you have manual hubs on front axle have them unLocked of course
00t444e
217
Southern OH
Ranger ext cab
Transmission in 1st gear transfer case in neutral, no need to pull the driveshaft.
lil_Blue_Ford
6,240
Butler, PA, USSA
4.9L
Yup, I’ve towed my Choptop on a tow bar and a tow dolly hundreds of miles now. Throw the T-case in neutral and have at it. You’ll want the steering unlocked though flat towing on a tow bar though, it follows the tow vehicle better that way. If you’re worried about having the key on and draining the battery, just disconnect the battery.
Also, double check the T-case is in neutral. I recently pulled the Choptop and had it sitting for a night with the T-case in gear so it wouldn’t want to roll anywhere. Forgot to put it back in Neutral the next day and tried pulling it. My F-150 dragged it but wasn’t real happy about it and it quickly dawned on me what I did. I was essentially trying to pull start a blown up motor and over-reving the snot out of it (doing 35 in first, lol). Good thing it was a junk motor, lol
