Hood liner deterioration.
CrimsonEclipse
Mazda
The liner underneath my hood is starting to sag and directly contact some engine parts.
Should I replace it, leave it alone or just remove it?
Does it protect the hood or is it for sound supression?
Thanks
CE
3,614
Its a lot of sound deadening. Its also heat protection. I'd go look for a new one.
7.5L_STX
73
Up Dere In Da U.P. EH!
unnecessary
take it off, ive always just pulled em off when they start to get torn/saggy
kunar
131
Toledo, Ohio
5.8l
its actually a fire blanket... if the engine catches fire, it melts the little plastic fasteners dropping it on the engine, hopefully smothering the fire (or at least slowing it down) thats what ive been told anyways...
zukirider21
5
NJ
2.9
dude thats sick haha
Ranger Dave (B25)
134
RFD/BNA/PHT
'10
Don't vote Democrat.
It's for all three. It's there for a reason. Don't remove it.
lil_Blue_Ford
6,240
Butler, PA, USSA
4.9L
Then the one that was in my choptop failed miserably. When I got the truck, the PO had done a bang-up job of cracking a head... there was a crack from top to bottom over the #1 cyl that was big enough to stick a fingernail in easily. Squirted hot oil all over the hot exhaust manifold and burned up a bunch of stuff. The hood blanket failed to drop... I later removed it because it was partially burnt and had become soaked in oil. I figured it was more a hazard than a help at that point.
None of the fullsize trucks either myself or my dad owns have a blanket under the hood.... odd...
bigcountry
new market
if it worries you that much just get some header paint and paint the under side of the hood. i know VHT makes a flame proof header paint thats good up to like 1,500 degrees and that should give you some piece of mind
Junk Collector
Truck of Month
4,868
Rapid City SD
I don't think it's meant to work that way.
