Help
jtm554
North Carolina
Ford ranger
I have a 1997 ford ranger the trans is going so I want to swap it is a 2.3l 4 cylinder 5 speed and I want to know if a 2003 2.3l 4 cylinder 5 speed trans would work
8,372
Welcome to TRS :)
No, the 2001-2011 2.3l is a DOHC Mazda L engine so uses a different bolt pattern for transmission
Your 1997 2.3l is a SOHC Lima engine, if a 2WD then 1988-2000 2.3l or 2.5l transmission can be use, model is M5OD-R1(M5R1)
But must be from a 2.3l/2.5l SOHC engine and 2WD, the M5R1s were also used on 3.0l and 4.0l engines but like the 2.3l DOHC they have a different bolt pattern
The M5R1s do not have a detachable bell housing like older manual transmissions did, so they are all Engine Specific
As a side note
Your 1997 was the last year Rangers had the "speedometer cable" hook up on the tail shaft of 2WD transmissions
Speedometer cable was not used but there is a VSS sensor in its place
So if you get a 1998-2000 M5R1 you will need to swap tail shaft housings and move the speedo Drive gear on to the "new" transmission's tail shaft, not a big deal to do
jtm554
North Carolina
Ford ranger
Is the bell housing interchangeable? Or is it solid
8,372
I added to my post
No, M5R1 bell housings are not removable, the bell housing and main case of transmission are cast as one piece.
jtm554
North Carolina
Ford ranger
What years have the same bolt pattern has a 97
rusty ol ranger
2.9 Mafia-Don
7,585
Michigan
177 CID
scotts90ranger
4,411
Dayton Oregon
2.3 Turbo
You need a '88 to '97 to bolt up and be as compatible as possible. The slave cylinder changed in '92 and the shift lever out of the top changed some around '95 I think...
What is the trans doing?
