help with pulley and belts
greenstranger89
i have an 89 ranger with a 84 5.0 in it all im looking to run is the waterpump and the altenator i need help finding a delte kit or a belt setup anyone got something that works thanks?
Teddyzee
December 2011 STOTM Winner
MTOTM Winner
15
Nova Scotia Canada
5.0L HO, GT40 heads, GT40 intake, 65mm TB, 1.7rr, Tri-Y headers, dual 2.5" exhaust, Flowmaster muffl
Should work fine with any alt bracket.
I've seen reverse rotation water pumps used, too (serp belt) just barely touching the bottom of the water pump pulley.
But I'll guess yours is standard rotation, so I see no probs.
greenstranger89
does it help if i told you the water pump turned counterclockwise and the alternator is mounted on the passengerside? is it ok that it only touch alittle bit?:icon_confused:
martin
26
St Bruno, Quebec
1991
If you put a slightly larger pulley on the alternator it would give you a little more contact with the pump pulley. you could also try moving the alternator a little to improve contact.
