Help with getting the right rotors
skeptikalone
6
Indiana USA
Ranger XLT 4X4
265 75R16
I have pulse vacuum hubs and I'm a little confused looking for replacement rotors. Do I need to remove the entire hub assembly and mount it to a new rotor or will I be able to slip the old rotor off after removing the caliper and just swap? I see some rotors with lugs and a hub included and some that look like regular rotors. Any information is appreciated. Tia.
8,372
1998-2000 should have separate rotors on 4x4, not part of the hub assembly, 2WD have rotor/hub combo units
You have to take the caliper off AND then caliper holder(2 bolts), and these 2 bolts are torqued at 85ft/lb so tight, caliper bolts are only 20-25ft/lb
skeptikalone
6
Indiana USA
Ranger XLT 4X4
265 75R16
Thank you. I was staying to second guess myself when I dug a little deeper at the products. Do you know the standard diameter of the rotor? I can't seem to find those specs anywhere. There seems to be different options for this year.
pjtoledo
2,989
Toledo Ohio
Fords
3.0 2.3
should be 11.25" easy to measure while still on the vehicle, just bend up a wire to touch the rotor edges.
