HELP WITH ELECTRIC FANS, WHICH ONE TO USE?
Proyecto_5.0
Mexico
Ranger XLT
HELP WITH ELECTRIC FANS, WHICH ONE TO USE? ... THERE IS NOT MUCH SPACE THERE.. WHICH SLIM FANS ARE BEST TO BUY?THANKS!
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Crossed threads are tight threads.
There's some good options out there these days. I got one off fleabay that comes with a fan shroud (makes a big difference), it fit fine.
You probably will like the flex a lite options, but they are spendy.
Josh B
1,986
Oklahoma
I thought they were just going to the wrecking yard and finding those in old BMWs or something
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
I think its out of volvos, but yea that's an option.
85_Ranger4x4
17,907
SW Iowa
Mercedes pusher twins fit a fist gen nice and keeps my 302 happy. Dunno how they fit a later truck, mine are out of a C230.
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
There you go, its the Mercedes ones. I heard of that before. It is weird they fit perfect.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
how much horsepower? if its a stockish roller engine hyundai fans...hell anything that will fit works.
if you are exceeding 300 hp....you need to open up the core...which will allow you to locate the radiator forward....and put a real radiator in there....with real airflow..
then you can use whatever fan you want. mechanical or electrical.
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
I am a fan of fans.
85_Ranger4x4
17,907
SW Iowa
Shoot, 302 in a 98+ I would run as much explorer as I could. Belt drive, fan, radiator etc.
Angie
368
Vancouver area BC Canada
92 & 83 project
4.0L 302
hey, i built this fan into a home made shroud on my build. the nice thing with this fan is that the motor is built into the shroud. saves room....
thread....
Junk Collector
Truck of Month
4,821
Rapid City SD
How much room you have depends on what front accessories and what radiator you have. I have the Duff/Northern radiator in mine and '86-91 Crown Victoria/Grand Marquis accessories... I hardly have room for electric fans and a mechanical one definitely doesn't fit. Explorer 5.0 front accessories open up a lot more possiblities. I had to run two fans (pusher/puller on both sides of the radiator) and had to cut out some of the grille to fit the outer fan.
Careful parts selection will help you a lot. This article may be helpful in selecting front accessories/timing cover/water pump so that you have the most room possible:
Josh B
1,986
Oklahoma
How many horses does a stock fan use ??
rubydist
860
Denver
Ford Ranger FX4
The answer that depends on the condition of the fan clutch. If the fan is running all the time it uses a good chunk, up to 10. If it decouples like it should, its more like half of that.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
a tight ranger mechanical fan is a minimum of 1hp...over 7 hp with clutch fully engaged
