mccombs
- Dec 11, 2011
- 0
So I'm going against the grain here and I need a little help to finish out my build. I'm not looking to use any parts from my old ranger engine (I've read you can reuse the pumps and alternator)
Here's my engine: http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=11752
306 crate motor from ford. I've got a Edelbrock Performer RPM intake manifold and a Holley 570 Street Avenger carb.
Here's what I'm thinking for the front:
Pulleys: http://www.jegs.com/i/March-Performance/655/30140/10002/-1
Belt: http://www.jegs.com/i/Gates/465/K060755/10002/-1
Alt: http://www.jegs.com/i/March-Performance/655/P560/10002/-1
Power steering: http://www.jegs.com/i/AGR/012/809102/10002/-1
AC: http://www.jegs.com/i/Denso/313/471-8112/10002/-1
I was also considering using this MSD Ignition: http://www.amazon.com/MSD-Ignition-8352-Dist-289-302/dp/B000BYAO9W/ref=sr_1_1?ie=UTF8&qid=1366584651&sr=8-1&keywords=msd+8352
Now here's the kicker - that pulley system says "Must Use Electric Fuel Pump with Kits That Includes Power Steering" that really throws me for a loop because I can't use that distributor that I've read was a good choice.
Frankly, I've not looked into how I'm going to handle wiring but at this point I'm a bit lost on what to order next. I need something that's going to work for a carbureted setup but is simple enough I can install. If I go with that pulley setup and accessories, what are my options to do an electrice fuel pump that will work with a carb'd system?
Anyone gone down this route? Can anyone point me in the right direction with these choices?
