Help Ranger won’t move
Joeyt2013
Cathlamet wa
Ford ranger
Hey there.... I have a 94 ranger 4.0 manual transmission. I recently ran into a problem where my truck won’t move it will start and go into gear but just revs doesn’t actually move no matter whether it’s in 4wd or not. I’m just looking for some advice as to what it could be.
ericbphoto
Overlander in development
16,663
Wellford, SC
3.0L
6"
First thing I would check is the clutch.
85_Ranger4x4
17,915
SW Iowa
If manual 4wd you might crawl under the truck and make sure the t-case isn't hung up in neutral.
85_Ranger4x4
17,915
SW Iowa
It’s a push button 4wd
Any weirdness from it? Shift motors are less than reliable and you still have a neutral position. I think the lights blink at if you if it screws up.
Joeyt2013
Cathlamet wa
Ford ranger
I can push the button and it stays on no blinking and I can put it in low range too and still no blinking
Do you have automatic or manual hubs?
If you have manual hubs unlock them, put it in 4x4, and jack the rear end up and see if both driveshafts will spin when you spin one.
You can do the same test if you have auto hubs, just expect the whole thing to bind when they engage. In this scenario that would be a good thing.
Shadowrider6661
D RANGED
ASE Certified Tech
129
Off grid Northern Arizona.
Stock
4"
N/A
33 x 12.50 x 15
Drive it, Break it, Fix it, REPEAT !
Remove the electric transfer motor and insert a flat blade screwdriver and rotate it to see if that changes anything. I have same setup on my truck and this was the easiest way to check for the problem. Its just a thought. I hope it helps.
