help im stupid
Wsljr2208
04 ranger 3.0 v6 2wd it is killing batterys in 5 minutesofrunning but the alternator is putting out 14.3 volts been through a couple of batteries only one new one but still the same thing checked all the grounds replaced one from body to the frame any help would greatly appreciated if any questions may help please ask will respond right away im kinda stranded at this point
Sent from my SM-J700T using Tapatalk
8,372
Check battery voltage with key OFF
12.8v is newer battery
12.5v is 3 year old battery
12.3v is 5 to 6 year old battery and time to shop for battery sale
12.2v or less is a "done" battery, can't hold enough AMPs any more
Start engine
Battery Voltage should now show above 14v but below 14.9volts
That should last less then 5 minutes at idle, over 10min is failing voltage regulator or battery(recheck battery voltage key off, after it sits for 4 hours, if voltage is dropping then battery has internal short)
After the 5min, you should see under 14v, 13.5-13.8v, voltage regulator has switched over to maintenance charge, keeps battery's available AMPs stable without over charging it
No, 14.3v won't kill a battery.............unless its AC volts
Switch meter over to AC Volts and see
Alternators generate AC Volts in the 3 Field Coils, this AC Voltage is changed to DC volts by Diode sets for each Field Coil, there can be an internal failure that can send out AC volts instead of DC volts, although it is rare its not unheard of
