help finding part number for ecu
utilitymoose
Nlv,nv
I have a 1993 4.0 ranger XL rwd manual transmission with California emissions(so I've been told, not 100% on that part) can anyone tell me what the ford part number is for my original ecu, or at least one that would be comparable to work in my truck? I fried mine and lost it in a pile of about 7 ecu's chasing down the bad ground that caused all my headaches over the summer. Vin is 1FTCR14X0PPB02593
8,371
Calif 4.0l engines should have EGR Valve in 1993 I believe, they didn't in other states
Ford uses part number 12A650 for ALL ECMs(PCMs), they still use it in 2018
They then add a pre-part number to designate year and vehicle model
F3 = 1993, F6 would be 1996, E9 would be 1989, 2000 and up are different
7F = Ranger
So F37F-12A650 is 1993 ford ranger ecu
The post part numbers(after 12A650) are where the problems come up, because Ford never publish anything on these numbers.
And they do denote engine size and transmission
And then there is the software number STAMPED on to the ECU label when Ranger was assembled, there will also be a white label with this number under the hood somewhere in 1993 models
This number also applies to engine/trans and emissions
and no published data on this one either
Some info on the software codes here: http://www.fuelinjectedford.com/page17.html
So look thru your pile of ECUs for F37F-12A650
And see if you can get the Post numbers and the software number
utilitymoose
Nlv,nv
Thanks, that helped a lot I ended up finding it in my pile and ordering a rebuilt one offline which just arrived. Runs way better, still need to fix this "cylinder identification circuit failure" and hopefully the truck will be able to be driven again
Confused ford owner
30741
Ford ranger
7F = Ranger
My ECU came out of a 1995 Ford ranger the label said it was refurbished and doesn't have a part number my cover has a part number of f57f-12b523 bc... When I look up the part number for my ECU which will be f57f-12b523, will it end with a BC as well??
8,371
Welcome to the forum
f57f-12b523-bc is the plastic holder for computer, so no, not something you need to replace unless it is broken
Seen here: https://www.ebay.com/p/1528726537
Or here: https://www.ebay.com/itm/165537752729
The Computer part number will always have xxxx-12A650-xxx as the center number string, in any year Ford
F57F is 1995 Ranger part, F5 = 1995, 7 = Ranger, F is the Ford department that makes the part
So your 1995 computer part number will be F57F-12A650-???
The suffix numbers -??? do designate what specific engine/trans the computer is for
But several suffixes mean the same thing, so finding an exact match is great if you can but not often possible
Ford never released a cross reference for these
If you don't have a sticker on computer with part number then you will need to find replacement that matches your specific vehicle
There are 3 things to match
Engine size, 2.3l, 3.0l or 4.0l in 1995
EGR or no EGR, 1995 should have EGR in most states
Manual Trans or Automatic trans
Confused ford owner
30741
Ford ranger
ok so my seal part number is f57f-12b523 bc and my computer part number would be F57F 12A650 ?? would it be (bc) as well?
my BCM part number was F57B-14B205-DG so would my computer part (pcm'ecm'ecu) end in DG??
8,371
No, none of those are related
The suffix is specific to that part only, not vehicle or model
If you don't have the engine computer's part number then you need to get one that matches your vehicles specifics:
2 bronco 11s
66
kentucky
ford bronco 11
here is a 93 explorer. it was a 4 X 4 but shouldn't make any difference. wouldn't hold water but ran g
Bought it for the 5 speed setup. Ran great wouldn't hold water. was a 4 X 4 . Shouldn't matter though.
8,371
Its a different person, he highjacked this older thread, from 2018
We don't know engine size or transmssion type just 1995 year and name is Confused ford owner, post #4
