- Aug 19, 2001
- 583
- So. Calif (SFV)
- Bronco II
- Engine Type
- 2.9 V6
- Engine Size
- 2.9L V6
- 2WD / 4WD
- 4WD
- Tire Size
- 35x12.50R15
Unless you have a suspension lift, the driveshaft should clear the crossmember fine (you will still need to remove the carrier bearing bracket pedestal from the member itself though). The truck you pulled your one-piece shaft from likely had this crossmember as well (just with nothing attached to it)Last question!!! Is it absolutely mandatory to remove the crossmember on the 1988’s as well? Thing feels structural to me, but perhaps not. Just want to be certain before i go chopping this truck up even more. Lol
It is mildly structural (possibly offering a small bit of support against the frame 'diamonding" in a collision), but the truck isn't otherwise going to fold up in half or come apart if it is missing.
