Luis garnica
- Mar 24, 2020
- 0
- Hyrum itsh
- Ford ranger
So I plan on doing a 351 window swap and 4x4 conversion on my 1985 ford ranger recently I found a bronco II that has a 351 with a 4x4 4 speed trans that was rolled over and the body was taken off the frame And I want to buy it to do the swap on my truck since the 351 was on a bronco II It should already have most of what I need to swap it I’m just wondering what it would take to actually get it in and running for example it doesn’t have a wiring harness but I’m wondering if I could just use the original one or if it has a hydraulic clutch or cable one as for the 4x4 conversion I’m also wondering how much harder that would be to do at the same time the motor also has no wiring harness but I’m wondering if all I would have to do to get it to run is wire the alternator and get a msd kit
