Danno1985
- Nov 20, 2018
- Reaction score
- 105
- Location
- MKE, WI
- Make / Model
- Ford
- Engine Type
- 2.3 (4 Cylinder)
- Manual
- 2WD / 4WD
- 2WD
- Total Lift
- stock
- Total Drop
- stock
- Tire Size
- stock
I put a fiberglass cap on my 2011 XLT for the winter and almost immediately noticed the back sagging a bit, so in addition to looking at some new coils for the front to level out the "Ranger lean", I'm looking into refreshing the rear suspension a bit as well. I've had great luck with Hellwig products in the past on my older Toyota trucks, so I thought the Hellwigs might be good in this application as well. Hellwig's site claims the 550 EZ springs fit up through 2011 model year, but after reading a review from someone with a 2011 claiming they didn't fit on their rear disc brake-equipped truck, I wanted to see if anyone here has tried them and has any additional info to share. Just to reiterate, mine is a 2011 with rear discs, which I believe started in 2010 with the advent of "Advancetrac". According to the reviewer, the issue was with the brake bleeder valves interfering.
