Any of the 4.0L OHV heads will work. The 95 and up heads have a different combustion chamber. Unless you know what your getting into I's stick with the early heads.
the only other engine that will bolt up to your transmission you don't really want. just get a newer set of heads for your 4.0L.......... or do a s/c saleen 5.4L swap with a mustangII front suspension conversion and r&p steering
i lied there is coolant in the oil. ugh hopefully i can hone the cylinders when i change the heads and get the rings to seat i refuse to rebuild this motor. i can get 250 bucks if i scrap it lol only payed 280 for it
true just figured it couldnt hurt since i have the hone. this is my first non chevy vehicle ive owned in 4 years and the first ford to be in this yard in 35 years.
change the heads, change the oil, run the engine for 2 or 3 hours (till it quits smoking) and then change the oil......... then beat it like a rented mule
For
a small yearly donation, you can support this forum and receive a 'Supporting
Member' banner, or become a 'Supporting Vendor' and promote your products here.
Click the banner to find out how.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
