Harmonic ballancer
J.Nunez
Winter Haven fl
Ford ranger
Hi I just recently installed new timing chains and guids and set timing and put #1cylinder at tdc with crankshaft key at 12oclock. Now my ? Is when I install the harmonic ballancer I noticed that the gap on the teeth of the harmonic is like at 12oclock but the camshaft positioning sensor pointer is right at the 0 mark where the Haynes book says it should be so is that correct because that is what the book says any help please?
I'm a little unclear on what the question is.
Did you just ask us if your instruction manual is correct?
Your balancer is only going to go on one way, unless you left the woodruff key out, so either you have it on right or you are magic.
J.Nunez
Winter Haven fl
Ford ranger
Ok lol well that would make since thanks
