2.3L ('83-'97) Harmonic Balancer Bolt
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
So Lima and duratec must be the same them. Im sure it can be a lil shorter..
I somehow doubt they are the same. Dunno never pulled mine off but the system in which they are attached is insanely different. Lima is keyed and not even pressed, it "shouldn't" require a puller to remove. The duratec bolt might even be torque to yield since it requires a very specific torque value to work (it's not keyed, and the balancer holds the crank pulley on which is also not keyed) the duratec system is friction only and if it let's loose your buying a new engine. Even loosening the balancer on a duratec before locking the camshafts will result in engine damage.
I could be completely wrong, but just based on how different the engines are I'd think the duratec bolt is larger, finer, or TTY. :dunno:
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
The bolt in question:
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I'd pull mine off to compare if you gave me the 400 dollars in tools to do it. :icon_rofl:
Ramcharger90
1,708
N/A na
306, Bcam,
The newer jeeps dont have a key way and the bolt is reusable..... 🤷‍♂️ dont know
Fredness
28
Sasquatch Country!
Ford Sport Trac
4.0L SOHC
The 4.0L is TTY.
I'm not sure about ours...
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Doesn't seem to be. Whats weird is you would think with all the dirt track guys, there wound be an arp bolt.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Dirt track requires a distributor ignition, aka old old block. (Pre 86?)
Dunno if they are different but I'd think the earlier ones with no crank trigger had a different bolt simply cause, science?
scotts90ranger
4,371
Dayton Oregon
2.3 Turbo
The crankshaft is the same all around I think, the '85 crank bolt is like 1/2" longer than the '89 style, probably changed in '86 with the small journal crankshafts.
FWIW, the distributor hole went away in '96 with the oil pump behind the aux pulley, the blocks had the distributor hole but a distributor wouldn't fit on the engine because of the lower intake manifold, change the cylinder head and you can now fit a distributor...
