Well...I completely brain farted myself
Pay attention class...don't do what I did
Follow directions!
Used liquid glass in my truck...but didn't follow directions...it states you drain the antifreeze, then put in nothing but pure water, then treat with liquid gas, run the vehicle a bit...THEN completely drain the water out and let sit for 24 hrs...then refill will antifreeze
I didn't do this and put it directly in...a few days later on my drive home from work...the truck started clacking like the hydraulic lifter was collapsing, pulled over and popped the hood, noticed the overflow tank had popped the lid and spewed radiator fluid under the hood, pulled the pressure relief valve and let the radiator bubble into the overflow tank. Started up again...had to stop 2x times again before I got home.
Noticed my radiator was almost completely dry the next time I drove the truck...short 3-4 mile drive, refilled radiator and got home, when I got home popped hood and noticed a steady stream of water coming off the water pump right behind the serpentine belt pulley (great...I just put this pump on there)
Turns out after I pulled the upper radiator hose to change the pump again I noticed what looked like dried paint in the hose (if you ever dumped out paint and let it dry, it forms a sheet of stretchy rubber like consistency goop, this was INSIDE the water jacket of my truck) so I decide well..time to pull the thermostat too...you guess it, completely gooped it up...almost NO flow thru the thermostat..yippie, I totally dumbassed myself.
so I scrape out all that sheet paint like goop...re-flushed the head/block with a waterhose saw little flakes of the stuff coming out, flushed the radiator w/ fresh water from fill hole and the hot sideneck, saw some flakes...got a new thermostat, gasket, and water pump (apparently the seals on the water pump don't like too much pressure on them...duh)
Well now I know the problem...ME
I also noticed that the new thermostat will NOT fit in the thermostat housing evenly...measured it...the stock thermostat is 26.86~mm the new thermostat (correct part number [I checked...the o'rilleys tech checked, we even got another one and checked]) is 28.38~mm, their $60~ thermostat housing the new thermostat dropped right in (along with the old that was a little loose) I guarantee the stock flange in the thermostat housing is too small...only way to fix it is to gently grind out the hole and make it a little bit bigger diameter so the slightly larger new thermostat will fit down in the hole in the flange...yippie (coincidentally the old thermostat does work...I had to clean it up because that goopy residue clogged it solid!)
click image for full size
Stock
New
Thermostat housing flange
Lessons learned, once I get it back together and get the new OBDII bluetooth diagnostics module and Torque app I will be able see the exact temperature (since my dash temp gauge is busted)
Then I get to start square 1 to see if it is still leaking and/or if the liquid glass did it's job
Moral of the story: Follow directions on a product specifically designed to seal up orifices that shouldn't be there...
