Gears needed after sas
NEVERDONE86
Rio Rancho, NM
2.9l
Ok..... Took the ranger out for a drive today in 2x. Couldn't get it going over 35 mph. I didn't do my research and now the engine is screaming to go 35. What gear ratio would you guys suggest for me?
I pulled out the stock axles with 3.73s and now I'm running 33" tires with a 4.10
I love the torque it has now but I can't take it anywhere without trailering it. All I want is 55 mph.
alwaysFlOoReD
5,093
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
That doesn't sound like a bad ratio for that size tire. What rpm are you doing at 35 mph?
NEVERDONE86
Rio Rancho, NM
2.9l
About 3000 in 5th gear
Mac
183
C. Wisconsin
2000
199
Something defiantly wrong and it's not your gearing, sounds more like 4 low gearing. With 33" and 4.10 gears, you should be turning 2720 rpm's in direct drive at 65 mph, see chart up in tech library.
Dave
alwaysFlOoReD
5,093
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I agree, I think you're stuck in 4-lo.
NEVERDONE86
Rio Rancho, NM
2.9l
I'll have to check the tcase. Thank you everybody!
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
with a 2.9 456 gears may be ideal with 33's on the street and 35's off road.
alwaysFlOoReD
5,093
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
^^^ I agree. I have 5.13's to put in my b-2 with 35" tires. But the OP's problem isn't what gears but what he's experiencing with what he has.
