Gaskets needed for 3.0 valve cover gasket replacement and what is up with the grommets?
Bgunner
1,090
Western Mass.
Ford/Ranger XLT
225/70/R15
As the title suggests I want to be sure there isn't a hidden gasket somewhere that I am missing and need to order to do the valve cover replacements.
So far I have in the cart: Valve cover gaskets, Valve cover grommets and the upper intake gasket (plenum gasket).
Is there one hidden somewhere that I am missing before I put the order in? Currently collecting parts for spring fixes and the last thing I want is to tear into it and not have the gaskets and not be able to put it together the same day.
What is up with the grommets? Most other gaskets I have seen have these molded into the bolt hole for the gasket. Are these meant to go between the bolt and the valve cover?
alwaysFlOoReD
5,125
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Bgunner
1,090
Western Mass.
Ford/Ranger XLT
225/70/R15
Anybody? I'm still waiting to be sure before putting the order in.
Ranger850
Doesn't get Sarcasm . . .
4,696
Tallahassee Florida
Stock 2"
Stock
Not sure, but IF they are cheap, get them. I don't remember having grommets on my '01, but its been a while since I've done motor work on mine. A Chilton/Haynes Manual will tell you where the grommets should go. or maybe someone here will chime in soon.
Bgunner
1,090
Western Mass.
Ford/Ranger XLT
225/70/R15
I'm pretty sure they go between the bolt head and the valve cover since the covers appear to look, and when tapped on, to be plastic. This would help prevent over tighening causing cracks but never pulled a 3.0 apart before so I would just like to be sure before tearing in to it.
stmitch
March 2011 STOTM Winner
MTOTM Winner
2011 Truck of The Year
649
Central Indiana
Yep, you got it! Really shouldn't need anything else.
Fredness
28
Sasquatch Country!
Ford Sport Trac
4.0L SOHC
Grommets seal the captive attaching hardware.
I'd get them.
Bgunner
1,090
Western Mass.
Ford/Ranger XLT
225/70/R15
Order placed and thank you all for the answers you provided. I just need warmer weather to start tackling the spring projects I have planned.
