- May 14, 2018
- 1,085
- Western Mass.
- Ford/Ranger XLT
- Engine Type
- 3.0 V6
- 2WD / 4WD
- 2WD
- Tire Size
- 225/70/R15
- My credo
- If it's not broken Don't Fix It!
As the title suggests I want to be sure there isn't a hidden gasket somewhere that I am missing and need to order to do the valve cover replacements.
So far I have in the cart: Valve cover gaskets, Valve cover grommets and the upper intake gasket (plenum gasket).
Is there one hidden somewhere that I am missing before I put the order in? Currently collecting parts for spring fixes and the last thing I want is to tear into it and not have the gaskets and not be able to put it together the same day.
What is up with the grommets? Most other gaskets I have seen have these molded into the bolt hole for the gasket. Are these meant to go between the bolt and the valve cover?
