Fuel line clip broke.
Donthekawguy
19
North Idaho
Well i put a new fuel pump in and of course the fuel gauge stopped working when I did. I went out to take the new pump out and one of the clips that holds one of the lines broke. It was the green one and now I cant get the line off the pump. I tried sticking a couple of tiny screwdrivers in each side with no luck. So before I take a hammer to it maybe someone has had the same issue and could suggest how to get this thing disconnected before I go gorilla on it. Also, does anyone sell the clips? I just got home from NAPA with a set that doesnt work.
Andrew.V
21
Manitoba Canada
2008 fx4 1988
4.0 5.0
90 degree pick from the bottom there are 2 small holes should be able to push it up through the top take your time. also a small zip tie will work to hold the fuel line on also I think dorman makes these clips
pjtoledo
2,965
Toledo Ohio
Fords
3.0 2.3
those clips have a lip on one side of the hole. push the clip in about 1/16" and the lip clears the ridge on the fuel tank line.
the clips do not come out.
they look like an oval with 2 tiny ears. the ears are the springy parts that hold the clip in the locked position.
after the plastic line is removed from the steel line the clip can be removed.
Donthekawguy
19
North Idaho
Finally got it out. My son came over and he has a cooler head than I do. lol Did the zip tie trick and it's all good.
pjtoledo
2,965
Toledo Ohio
Fords
3.0 2.3
BTDT
my first one came out in 2 pieces. zip ties are still holding it on.
Andrew.V
21
Manitoba Canada
2008 fx4 1988
4.0 5.0
Glad to hear you got it out and the good old zip tie worked again
