Front Swaybar
Vindictus
330
NewBrunswick Canada
ReMan 4.0 SOHC
Today I went at the task of changing my front sway bar bushings
I measured the sway bar at 1 1/16 or so I thought
I ordered 30mm bushings and there to small
with the sway bar removed I measured it again and it is 1 3/8"
I can't seem to find a 34mm bushing does any one have any suggestions on where to look
superj
2,619
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
I hate when bushings are a hair to small. It always agravates me so much because you are already at the point of no return when you find out
Vindictus
330
NewBrunswick Canada
ReMan 4.0 SOHC
I bought the truck new in 2011 it has the sway bar that came on it from the factory
Are you sure you didn't measure it to be 1 3/16"? There were only two options, 27mm and 30mm. If you do have a 1 3/8 bar it is obviously not stock.
Here are some generic 1 3/8 sway bar bushings.
I am positive I measured 1 3/8" and I just checked again and it's 3/8 not 3/16
Thank you for the link
The bushing I ordered were 30mm and the are 30mm
superj
2,619
ranger edge
none
none
235s
No bushings on the self help wall at the local auto parts place? Oddly, my local advanced has that kind of stuff
Vindictus
330
NewBrunswick Canada
ReMan 4.0 SOHC
Sorry to say I live in the back end of bum f*** and don't have that option
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,687
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
The last time I had to muck around with sway bar bushings, I had the same issue and had to use sandpaper on a drill driven drum to make the bushing opening larger. This was not on a Ranger. If you choose to go that route, speed is your enemy. You want to abrade the material, not melt it. It will take some time and stop often to check fit.
Yotaismygame
196
Oregon
Splash 2wd
Dang that sway bar is way thicker than my stock 95 one. I'm gunna need to make a trip to the junk yard. You're positive on the diameter? Used calipers I take it? I had been looking at belltech and hellwig sway bars and they come in 1.25 or smaller.
Found a thread on another ranger site and people are commenting their rangers have a 33mm sway bar and found explorer bushing's were the correct size.
cbxer55
767
Midwest City, Oklahoma
Yeah, the factory front bar on my 98 Ranger is nowhere near 1 3/8. That's a YUGE bar.
Vindictus
330
NewBrunswick Canada
ReMan 4.0 SOHC
Yes I used digital calipers
When I get home tomorrow night I'll snap a pick and post it
Vindictus
330
NewBrunswick Canada
ReMan 4.0 SOHC
Son of a bi*** We junked a sport trac at work a couple of weeks ago and I forgot to swipe the rear sway bar.
Don't get OLD first thing to go IS the MIND :(
oldgeek
1,027
USA
Ranger XLT
I thought it was the ability to pee well. The urine backs up, your eyes cross and then you are unable to think of anything else.
Vindictus
330
NewBrunswick Canada
ReMan 4.0 SOHC
urine doesn't back up anymore it freely runs down my leg:confused:
