Freeze plug popped out.
Ramcharger90
1,708
N/A na
306, Bcam,
So the freeze plug popped out of the 5.0. Has anyone ever seen this before?
snoranger
Professional money waster
ASE Certified Tech
13,721
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
8,372
Yes, +1 ^^^^, seen it before
If its hard to get too use a rubber expansion plug to replace it, works the same to plug the core hole, just more expensive than the metal hammer-in type
ericbphoto
Overlander in development
16,729
Wellford, SC
3.0L
6"
I haven’t seen it. But I’ve heard that’s what they do.
Ramcharger90
1,708
N/A na
306, Bcam,
Ok I wasn't sure if I killed her normally that happens when pressure gets in there. But it runs fine and the oil looks clean and isnt mixed in
It shouldn't be too bad its in between cylinder 1&2
Ramcharger90
1,708
N/A na
306, Bcam,
ericbphoto
16,729
Wellford, SC
3.0L
6"
Those are supposed to keep the coolant in. I wouldn’t run it until it’s fixed. But that’s just me.
Ramcharger90
1,708
N/A na
306, Bcam,
I figured I go to California like that.....
Ramcharger90
1,708
N/A na
306, Bcam,
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
On my 460 i built into a 557ci I tapped the freeze plug holes. Suppose to stiffen the block. Dunno if it holds any merit but i was bored.
Ramcharger90
1,708
N/A na
306, Bcam,
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
Yea... not something you wanna do on a engine you actually use daily. Freeze plugs do serve an important function. I did this on a engine intended just for racing.
Ramcharger90
1,708
N/A na
306, Bcam,
For a 460 im probably gonna do next
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
I still have the two taps you need if you ever do decide to do it.
