FM signal worse than AM?!
rumblecloud
1,122
48022
Ranger Splash
1-1/2 inch front leveling
Stock
What's the worst that could happen?
Yes, you read that right. 94 Ford Ranger Splash. This is the original factory radio. Never been messed with. This just started a few days ago. Prior to this it was fine. Now I can barely pull in any FM stations. AM works loud and clear. I don't know where to start. I recently installed new heads and removed the hood - which meant I disconnected one of the braided ground straps. There were two, but the driver's side strap (from the hood to the basckside of the engine) was corroded and not connected. I replaced it. The passenger side was clipped from the cowl to the hood. I replaced this one as well. I don't even know if ground straps can cause this.
I know it's something I did but the timing doesn't add up.
Any ideas or direction would be a big help. Thanks in advance.
RobbieD
2.9l Mafia
3,470
Georgia
Hood grounding is mainly to reduce electronic interference static on the AM side. I can't think of anything external to the radio which would cause loss of reception on the FM side. If it was antenna problem it would affect AM side more than FM. I'm trying to remember; doesn't the factory radio have an FM1 and FM2 preset selection? If so is there any difference between the two?
8,370
It is most likely a radio issue if AM is working OK
Do ALL the AM stations work fine?
Does the radio have a scan feature, if so does it pick up the local FM stations but you just can't hear them very well or does it not find them?
AM and FM use separate "local oscillators" to "see/tune" stations, so FM can fail but AM works fine
And it just happens, not related to anything else, just breaks one day
You can pull radio and test antenna using an OHM meter, but if AM is working on all stations antenna is most likely OK
tw205
Bronco II Rancher.
976
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
6” skyjacker 2” body
33x12.5
OMG. 🤦🏼‍♂️ People may think your serious. Nah. It’ll be fine.
tw205
Bronco II Rancher.
976
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
Dude. Sounds like your radio just broke.
rumblecloud
1,122
48022
Ranger Splash
Stock
Yep. Factory radio has FM1 and 2. Both are the same lousy. However, I went out for a test drive this evening. I switched to the FM band and tuned to an FM station to listen to nothing. About five minute later, it just came on, loud and clear. SO there's a gremlin somewhere. So maybe tw205 is right.
To RonD: All AM stations work great - well at least the ones I can pull in - quite a few. The scan feature seeks and finds FM stations. I just just can't hear them very well.
I need to go to the SOS and get me a gremlin permit. Thank you all for your help - especially tw205 :yahoo:. I will update if it's worthy.
8,370
You need a new radio
pjtoledo
2,965
Toledo Ohio
Fords
3.0 2.3
put a 3 foot or longer piece of wire in the antenna connector. does it work now?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Back in my day we didn't even have "FM"
Suck it up!
rumblecloud
1,122
48022
Ranger Splash
Stock
I know you're serious. But, a new radio is a luxury item right now. I have to take it easy for a few days...or a few paychecks... or one or two VISA bills. :p
Weasel
9
Canada
Ford Ranger XL
AM can work OK without a good antenna, but FM usually won't. Check to see that the antenna is properly grounded.
racsan
4,443
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
am has a longer range, my favorite fm signal is only good for a 30 mile range of where I live, am radio I can get anywhere in the state, but it sucks-mostly talk shows and sports programs. The escape can get a few free sirius satellite stations, those are great, theres a 80’s classic rock staion thats really good. And except for bad weather the reception is always good, even out of state.
