flat tow 4wd
mosher41
Macedon, NY
guys,
I am looking to tow my 04 XLT 4.0 auto, 4wd behind the motor home. Ford offers a neutral tow kit part # 3L2Z-7H332-AA. Our local dealer says NO.... any ideas here guys
mattpresley
13
Mesa, AZ
FORD F-250
6.2
Solid Axle Swap 4x4
guys,
Rent a small flatbed trailer from Uhaul. CHeap and the best way to go for the ranger
Big Jim M
30
Austin
I have towed all makes of 4x4's over the years. But they all had a neutral in the transfer case. If you can get that transfer case in neutral that would be my choice instead of that u-haul trailer. I always put the transfer case in neutral and the real transmission in PARK or LOW if it is a stick shift. Thataway I know for sure the transfer case is truly in neutral.
Big JIm
Jspafford
Logan Andrew Feb 17, 2012
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
If there is a neutral kit for the transfer case, ask ford to explain why it won't work on your truck. Then go to another dealer and ask them. If you get the same answer twice, they are probably right and I wouldn't want to risk it.
Nhaz
4
The Great White North, Ottawa, Canada
1998 and a few
Ranger+Ranger+E
4.0 3.0
If you are really worried about it. Dropping the drive shafts isn't all that hard. and pretty much guarantee's you won't have problems.
AllanD
135
East-Central Pennsylvania
1987... sorta
'93 4.0
Big JIm
the specified proceedure is T-case in neutral transmission
in Gear (manual) pr Park (auto)
I've towed my own truck from my home in pennsylvania
to my brother's place in Wyoming.
Flat towed I have permanantly mounted tow bar brackets on my truck, T-case in neutral trans in gear.
AD
Ranger97XL
ditto, best way to guarantee nothing happens
Will
514
Gnaw Bone, Indiana
Toyota
guys,
See if >>THIS<< helps. Looks like that kit is for 2006+ trucks. And earlier trucks may have something added that wasn't there back when most of our trucks were built. It's very confusing and I am in the remove the driveshaft camp on this unless I saw what it was that allows you to put an electric-controlled t-case in 2-hi and tow it with the manual tranny in neutral. Did they move the lube pump in the t-case?
mosher41
Macedon, NY
sorry guys I should have worded it different, Ford Dealer says he can't get the part. and I am not even sure how it works or what it really does....not into taking drive shaft out. We use a saturn now but it is getting tired
7
murphy north carolina
2.8 v6
its just 4 bolts well on mine it is should be the same idk keep the socket with u or in the truck u dont have to take it out just tie it up under there or zip tie it good not much and its free
Will
514
Gnaw Bone, Indiana
Toyota
I don't think it will work on a 2004, according to that TSB, is what I'm saying. I found this:
Have 07 4x4 Auto Supercab. Ranger
Dealer installed "neutral kit", actually just a LED indicator light ($25) and dealer computer programming. My dealer charged $110 for the install with kit.
Brake: Ready Brute+ w/BlueOx baseplate, only way to go, IMHO.
2009 Tow Guide shows same kit I have...3L2Z-7H332-AA
It leads me to believe there is something different about your truck from the later trucks. Maybe the electric shift motor can be put into neutral with this kit. You can definately order it. I found it by googling the part number. I saw one on Ebay, too, but was using just the 7H332 and didn't verify the rest.
mosher41
Macedon, NY
Guys thanks for all of the responses....the only way to tow this truck flat is to put a drive shaft coupler in it REMCO makes one for a cool 1200 beans. Probobly go that route. THANKS AGAIN for the direction
David Moore
2010 Ford Explo
Ford Neutral Tow Kit
According to Ford, the neutral tow kit can be ordered in March but is not expected to be availabe until April. None are available on the Ford locator, even tried in Canada. I'm waiting for one for a 2010 Explorer. We may end up renting a trailer......or leaving the darn thing in the desert!
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Put a Shiftster on it....it has a neutral locking position.
basilfaulty
4
This kit is no longer available from Ford. It consisted of a computer reflash a decal and an LED light to indicate it was in neutral. The reflash told the computer that if a certain sequence of events happened the electric shift motor would shift the transfer case into the neutral position (between 4 hi and 4 lo), the decal was instructions for the proper sequence of events to put it in neutral and the LED confirmed it was in neutral. From what I understand the kit is no longer available because the company the wrote the reflash program was now in a dispute with Ford and no longer makes the program available. The program was not downloadable to a disc and was available for a fee per use and VIN coded. If Ford ever settles the dispute it will probablt again be available. For now you could take the shift motor off and manually shift into neutral or do as I do remove the rear shaft. If I get somewhere along the way and need to drive the Ranger I just put it in 4 hi and drivr it in front wheel drive....if I am going to drive a long distance it is easy enough to put the shaft back in.
