Finally, my official project truck
ericbphoto
Overlander in development
16,598
Wellford, SC
6"
Another late night in the garage.. I had to get the torque monster headers fixed. I bought them used and for whatever reason the driver side was chopped up. Long story short, its back to original condition! Exhaust is scheduled for the 21st or 22nd.
So on this hydraulic setup, F550 master and 280z slave..
I'm only getting about 1/2-1 inch off the floor then the clutch engages . That will not work for me. Whats everyone else running and where is your clutch engagement coming off the floor...
Thats one of the fanciest portable worklights I’ve seen.
2drxploder
436
usa
ranger
347
lower
235 on 15s
I haven't put it in yet.. but yes, stock hanger and stock tank. This is the one I'm using..
EDIT: posted wrong link. Right one below
i ordered a gss342 not 340. hope it still works
edit: after some reseaerch seems they are same other than inlet size and location, 340 has bigger inlet to work with older stangs, all flow the same
Junglejoe
66
Columbia Missouri
6.0
Thats a big pump... whats your setup?
2drxploder
436
usa
ranger
347
lower
235 on 15s
347, bcam, 1.7 rollers, still using stock expo heads n intake, tm headers if they ever arrive, and a t5. Also still waiting on clutch n flywheel to arrive b4 I wedge it in. Hopefully all will arrive before Xmas, so I can install during Xmas break
Junglejoe
66
Columbia Missouri
6.0
Nice...
You'll find that its easier to put the engine in.. then the bellhousing.. then the transmission
Junglejoe
66
Columbia Missouri
6.0
Going to see if I can make a little noise...
3 inch SLP Loudmouths. Just a temporary thing. Later I'm doing a rear tank conversion and redoing the exhaust with Black widow venum 250 mufflers
Roert42
4,961
Kintersville, PA
Ranger XLT
4.0 SOHC
I have a set of SLP loud mouths on my mustang, and I have friend with a set on his GTO. Both have long tube headers, sound awesome.
Junglejoe
66
Columbia Missouri
6.0
Yeah I've heard them on youtube.. just a little to much for me..lol
Draws to much attention on them "test runs"😎
Junglejoe
66
Columbia Missouri
6.0
Exhaust is done. Worked over Torque Monster headers, 2 1/2 duals to a 3 Inch X pipe to 3 inch tail pipes all the way out back.
Junglejoe
66
Columbia Missouri
6.0
Had to re-adjust the valves on the truck, got it back together. Hopefully dont have to pull the valve cover back off for a long time!
ericbphoto
16,598
Wellford, SC
6"
Uncle Gump
Token Old Guy
13,462
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I MUST RESIST TEMPTATION....
