FE Lifters in a Cologne
Uncle Gump
Token Old Guy
13,460
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Interesting to note, I'm not entirely sure that the lifter adjustment write-up in the tech section is entirely accurate, now. Apparently the recommended procedure is to take up clearance, then adjust down 2mm.
This would be for a hydraulic lifter.
You would open the valve 2mm plus rocker ratio using that on a solid lifter. And most likely destroy stuff...
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
So... which one do you have?
BV I believe. Can't find any references that spell out the differences. Not sure what they would be.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Correct haha. The book)/ tech page suggests to contact, then 1.5 turns. This is saying (I.may be misunderstanding) that you literally turn till you can't easily spin the pushrod, then go 1.5
Uncle Gump
Token Old Guy
13,460
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
You aren't misunderstanding... that is the method.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Anyone out there know what the difference is between these two styles of mechanical lifters?
I know the bottom one looks like a hydraulic, but Comp has it listed as a solid / mechanical. Wondering what the "waist" in the middle of the first one is for/does?
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
ericbphoto
Overlander in development
16,598
Wellford, SC
6"
Uncle Gump
Token Old Guy
13,460
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I've never seen a mechanical lifter you could disassemble... the bottom lifter sure looks to be a hydraulic.
The undercut "waist" on the top lifter seems to be more extreme then others I've seen... sure seems it would be less restrictive to oil flow through the lifter galley.
That's all I got PJ...
19Walt93
4,465
Canaan,NH
351
3"
235/55R16
Most domestic solid lifters look like the bottom one, I suspect the top one has a cutout so some engineer could claim he saved 1/2 oz of metal per lifter. If you put solid lifter against a hydraulic cam you'll end up with extreme wear and metal particles in your oil, the lifter bases are shaped slightly different. Roller lifters reduce friction and parasitic drag and allow steeper ramps on the cam lobes. That means you can have a relatively short duration cam and still have the valves open further and longer for better power without hurting the low end. You also don't need high zinc oil.
The FE engines were introduced in 58 as a 332 and grew to 352,360,390,406,427, and 428. They were good engines until the 75-6 model years when the machining equipment was wearing out, we had problems like sand holes in the block leaking coolant internally and noises from sloppy tolerances. The cast iron intake manifold weighed about 95lbs and lifting one out while leaning over the fender kicked my butt in my 20's, I'd use a motor crane now.
Uncle Gump
Token Old Guy
13,460
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I certainly haven't seen them all Walt... but of the solid lifters I have used... never seen one you could disassemble.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
There's also the anti pump up flavor of hydraulic lifter available. Never heard of them before, but until now I've never given lifters much thought.
They seem interesting:
"The aftermarket has developed some variations on the standard-issue hydraulic lifters. One of the first refinements was the introduction of anti-pump-up lifters. The concept is as simple as it is effective. In an anti-pump-up lifter, the light-duty retaining clip at the end of the hydraulic lifter's internal plunger travel is replaced with a heavier, more positive stop.
When used in conjunction with an adjustable valvetrain, an anti-pump-up lifter can be set so the internal plunger is at or near the top of its range of travel when the camshaft is on its base circle. When running, the anti-pump-up lifter is essentially adjusted so the piston is already pumped all the way up against the stop, eliminating the possibility of the plunger overextending. An adjustable valvetrain is, of course, required to utilize an anti-pump-up lifter as intended. Anti-pump-up lifters may also include changes to the lifter's valving or clearances to alter the bleed-down characteristics, although current theory holds that "stiffer" is better."
8thTon
--- Banned ---
806
Pennsylvania
Then there are Rhoads lifters with controlled leak down to reduce lift/duration at lower rpm - always thought that was kind of clever but no idea how well they work.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Saw those as well, but couldn't remember when I posted. No clue which would serve best.
Paulos
210
North Carolina
1987 STX
@ PetroleumJunkie412
I'm not sure if I linked to this in the past, but have you checked out this solid lifter conversion? Just the kind of mod I'd think you would experiment with :). I've considered doing it myself if I ever do the free-floating rocker arm mod.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Saw that one a while back, but think im going to pursue an aftermarket solution.
Farmer ghosted me, so sent the cad files that I drew up for the rocker spacers to a bunch of machine shops. So far, cheapest one quoted me $360, which means not happening.
Glad I put all that work in ?
