Uncle Gump
Token Old Guy
- Sep 17, 2018
- 13,460
- Ottawa IL
- Ranger/BroncoII
- Engine Size
- 4.0L SOHC/2.9L
- 2WD / 4WD
- 4WD
- My credo
- Lead follow or get out of my way
This would be for a hydraulic lifter.Interesting to note, I'm not entirely sure that the lifter adjustment write-up in the tech section is entirely accurate, now. Apparently the recommended procedure is to take up clearance, then adjust down 2mm.
You would open the valve 2mm plus rocker ratio using that on a solid lifter. And most likely destroy stuff...
