Adding another video that demonstrates the wandering RPMs and also the difference of engine sound from warmup to post-drive hot startup.
After all this work, the most promising thing is that the engine sounds quite a lot smoother and quieter than it ever has, when it’s not ticking. This is heard in first part of video. So I know it has the ability to be smooth mechanically. The second half it sounds like a diesel. This comes and goes.
But the idle/RPMs still waver a lot no matter what. One time after a hot startup it swayed back and forth from 1K to 2K, every second. I kid you not! But below, in both the first part and second part, I’m holding the throttle perfectly steady at 2K and it still wavers up there. Then I drop it down to idle which also wavers a little.
I think at this point that i have checked every vacuum line/connection and tested with the mighty vac and I’ve replaced a few slightly leaky connectors but it hasn’t made any diffence. I also put a new hose from the plenum to the back of the fuel regulator.
I could see the short jitteryness at low idle being fuel/pressure related. But I just filled the tank before the second half of this video and drove it around before recording that part, so it doesn’t seem like air being pulled from fuel / tank is the direct cause of steady back and forth wandering RPMs. So at this point I don’t what else to attribute this to other than the ECM just running the RPM’s up and down for some reason. It’s not usually 1K to 2K, it’s usually only a difference of 200-300. But it hasn’t gotten better after like ten short trips of driving.
Next up.. opening up ECM and taking a look. Maybe it needs new capacitors somewhere?
Shared with Dropbox
www.dropbox.com
