Explorer to B2 5 speed swap
Kwazie
Southern Maryland
2.9l
Looking to do a auto to manual tranny swap. Found a donor 93 EB and know the trans will swap but what about the other parts like pedal assembly, master cylinder and steering column? May need the shafts too due to M5od vs A4LD length but not sure. Going into a 90 B2 that is showing signs of pending failure. I have read here of swaps using ranger or b2 parts but no info on Gen I Exploder except engine swaps. Can I use it or do I need to keep searching?
snoranger
Professional money waster
ASE Certified Tech
13,654
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Your shafts will work, as long as you dont swap the 13-54 T-case from the Exploder in also.
The 1st gen Explorer used 2 different masters. An early and a later one. A 91-92 master is the right one for your truck, but I would get a new one.
Also replace the slave while your there. Dont play with used parts.
