Good general info here on the Lima engines:
http://www.therangerstation.com/tech_library/4cylinders.shtml
Couldn't find a "map" for the '85, this is an '89 so has Distributor-less ignition system:
http://www.justanswer.com/ford/1dhg5-intake-air-temp-sensor-located-1989-ford.html
But you really don't have alot of sensors.
MAP sensor on the passenger side firewall, it has a vacuum hose and 3 wire connector, you can find it that way, it is not large, it is the main sensor the computer uses to set the fuel/air mix, needs a good vacuum hose with no leaks to do it's job.
ECT sensor tells the computer the engine coolant temperature, this temp decides if computer runs engine rich with high idle(choke mode for cold engine) or lean with low idle and good MPG(warmed up engine).
ECT sensor is on the drivers side of the block, towards the front.
ECT SENSOR has 2 wires connected, there is also a 1 wire SENDER that looks similar, but it is for the dash board temp gauge.
Distributor has a sensor inside that sets the spark and injector timing.
You should have an IAT(intake air temp) sensor on either the upper intake or air filter housing.
You already know about the O2 sensor and TPS.
