I know the T shape bracket probably won't fit the Ranger's 3.0 Vulcan V6. I was hoping for something like this pair:
They look like carefully design to provide balanced lift. Those were from the 2007 Ranger workshop manual for 3.0L. Older 2000-2004 manuals have these single-bolt lifting eyes, which I don't like:
I have a standard garage, opens to a slight uphill, so I chose to lift the engine side-way. I used
two 6-feet nylon sling wrapped around the exhausts. At first, it seems good, then I reached the limit of the crane before the oil pan clear the bay, yeah, a forehead banging moment. Several things went against me: 1) the sling slacks are too long, 2) I didn't lower the jack stand as much as possible, 3) I didn't extend the crane neck longer to gain more height.
First thing I did was to lower the truck in small increment while lower the transmission stand. After that, the pan still couldn't clear the fender. Then I removed the pan in mid-air above the engine bay. I also had to remove the oil pickup bolt to turn the pickup 90 degree. That finally cleared the truck.
If I had that pair of lifting brackets, I can adjust length of the chain to the crane, something I couldn't do with the slings.
